Problem debugging in different schema
RogerK
Though having the "debug any procedure" privilege and the debug object privilege (through a role),
debugging a package in a different schema does not work. When using the test-window, the debugging process calls and correctly processes the function, but does not step into it, even when i try to set a breakpoint. Is there any way do solve that problem ?
The way I do it is to compile with debug in my own schema, do my debugging and fixing, then submit the changed code to be compiled in the target schema.
Another user's package bodies will only be visible if you have select privileges on the sys.dba_objects and sys.dba_source views. The "Use DBA views if available" preference (Tools > Preferences > Options tab page) needs to be enabled.
Thanks for your comments. But all the prerequisits
you mentioned are fullfilled (Debug Info added, dba_objects, dba_source accessible, USE DBA Views enabled).
Any ideas ?
Roger
i was able (unfortunaltly only in a test environment) to obtain the create any procedure privilege, which is necessary to see package bodies in different schemas when using all_xx views and it works !
Does that mean PL/SQL-Developer does not use dba_views though requested in that case ?
The same thing applies to "compare objects" when specifying a different schema name on the target database.
Roger
It's actually a restriction of the Oracle Debugger. PL/SQL Developer can show the objects if you have select privileges on the dba_objects and dba_source views, but the debugger won't step into these objects if you don't have this system privilege on 9.2.
