View package bodies from other schema
phocai
Can someone tell me if it is possible to view package bodies and triggers belonging to one schema from a different schema? We are using PL/SQL Developer 5.1.2.682 and have only been able to view package specs from the browser. Many thanks.
Make sure you have Tools> Preferences> Options Tab> "Use DBA Views if available" checked.
[This message has been edited by cassiusdrow (edited 19 May 2003).]
Hi, did you ever get this working? I set the option that was sent to you in reply, but I still can't see the bodies in other schemas. I'm on 5.1.3.704. Appreciate any help you can give.
the way i do it is to browse through the "users" folder, expand a user, expand "objects", expand "packages", select a package, right click and select "view spec and body"
works well
of course, it helps if you are logged in as "sys"
richard.brooker@vuw.ac.nz
[This message has been edited by rbrooker (edited 25 July 2003).]
You will need select privileges on the sys.dba_objects and sys.dba_source views. You also need to enable the "Use DBA views if available" preference as stated above.
This should do the trick.
i have successfully set up pl/sql so that i can view packages owned by other users, as described above) however i cannot see the triggers. Is this possible?
You'll probably need select privileges on dba_triggers (and dba_objects).
