toddaron
Hello!
(My) First post. Please be gentle!
v10.04.1708
Ora 11.2.0.2.0 64 bit
I'm trying to test all cases of a call. Nothing earth-shattering; nested loop, call to proc.
I'd like to step over the call and on return, examine the cursor for each call. I'm successfully doing the step, but when I select "View Collection Variable..." from the popup menu, no window opens.
When I run the thing with no loop, its fine, returns what I expect. But, in the loop, I'm getting:
(Rowcount = 0, %open, first iteration)
The called procedure builds some SQL and executes it, puts it into a nested array, massages it, and returns it as a ref cursor.
Again, the original, loop-less version works fine each and every. But, I'd like do this in a loop, rather than enter...
... each...
... and...
... every ...
... possiblevalue ... .
Help? Following is a culled approximation of the code.
declare
vID varchar2( 10 ) ;
vCursor sys_refcursor ;
for i in
( select *
from MyView
loop
for j in 1 .. 3
loop
vID := case j
when 1 then 'Alabaster'
when 2 then 'Boise'
when 3 then 'Calamari'
end ;
TheSchema.ThePKG.TheProc(ocursor => vCursor
,p1=> i.KEYFIELD
,p2 => vID
-- Stop here after every call
end loop ;
end loop ;
v10.04.1708
... each...
... and...
... every ...
declare
for i in
( select *
from MyView
loop
for j in 1 .. 3
loop
vID := case j
when 2 then 'Boise'
end ;
,p1=> i.KEYFIELD
,p2 => vID
end loop ;
end loop ;
