I'm trying to figure out regression testing and the test manager. I'm really a newbie to PLSQL.
So, my objective is to make the cursor :x a global variable which can be referred to in other test scripts in that test manager group, then i can loop over that cursor...
Only I get ORA-=01001: invalid cursor, ORA-06512 at line 9 (that is, FETCH c INTO v_code, v_desc . Seems I did something wrong...  i can see that in the Run Log under Input Vvariable values, x = "", so i don't know sure what to do.
		SQL:
	-- Created on 6/23/2025 by ZITOT
declare
  -- Local variables here
  c SYS_REFCURSOR;
  v_code  varchar2(6);
  v_desc  varchar2(30);
  -- Test statements here
  OPEN c FOR
    select term_code,
           term_desc
      from term
    where  term_code > '202400'
       and term_code < '202600';
  :x := c;
  LOOP
    FETCH :x INTO v_code, v_desc;
    EXIT WHEN :x%NOTFOUND;
    DBMS_OUTPUT.PUT_LINE('Code: ' || v_code || ', Desc: ' || v_desc);
  END LOOP;
		SQL:
	-- Script #2
-- Now: Use the cursor
DECLARE
  v_code  varchar2(6);
  c SYS_REFCURSOR;
  c := :x;
  LOOP
    FETCH c INTO v_code, v_desc;
    EXIT WHEN c%NOTFOUND;
  END LOOP;
  CLOSE c;
    --FETCH :x INTO v_code, v_desc;
    --EXIT WHEN :x%NOTFOUND;
    --DBMS_OUTPUT.PUT_LINE('Code: ' || v_code || ', Desc: ' || v_desc);
  --END LOOP;
  --CLOSE :x;
END;
//Only I get ORA-=01001: invalid cursor, ORA-06512 at line 9 (that is, FETCH c INTO v_code, v_desc
