Test window HTP output retrieval very slow
Worker
When I run a test script that uses HTP to produce output, the script finishes quickly but then PL/SQL developer hangs for as much as 10 minutes while it retrieves the HTP output.
I peeked at the network traffic and it looks like PL/SQL Developer retrieves HTP output one line at a time using something like:
  htp.flush;
  :line := htp.get_line(:rows);
Since htp considers a "line" to be 256 bytes (or less) please consider speeding this up by getting multiple "lines" at a time. I use code similar to the following:
-- get_line returns up-to-256-byte "lines".  Call that up to
-- 126 times to get up to (126*256=) 32256 bytes per round-trip.
declare
  local_rows number := 0;
end
  htp.flush;
  while ( :rows > 0 and local_rows < 127 ) loop
    :line := :line || htp.get_line(:rows);
    local_rows := local_rows + 1;
  end loop;
Note that you can get even better performance by binding something larger than a 32k string to the block for output (like a clob or an array of strings). The less often the declare..end block is executed, the better.
