Test Manager - strange output
ainsd
In the test manager window I have a series of tests along the lines of ...
Input / Output values
Variable name Input value Output value
p_template_id...1
p_valid.......................Y
On running the test manager script, I get run results ...
Result
Variable p_valid: required "Y", actual "Y
i.e. Missing " character.
The run should pass with these parameters, am I missing something or is this a bug?
David
Hi Marco,
I think I've solved this!
The out parameter that I was testing was defined as CHAR and the test script variable type was set to String. I changed the out parameter to be VARCHAR2 and then the test manager produced expected results.
Similarly if I change both the out parameter type and the test script variable type to CHAR then all is fine.
Cheers,
David
