Taskbar Connection info is not correct
jking
I am noticing that the connection info in the Taskbar (schema@database) does not always match the actual connection that PSD is currently connected to, which is reported in Title bar. It seems like the Taskbar always shows the previous connection.
There are no pinned connections. Every window is using the main connection. I can't always reproduce it and can't figure out what may cause it to happen sometimes. It does happen quite often though.
I am running WinXP and PSD 10.0.2.1697.
Thanks.
I cannot immediately reproduce this. If you find a pattern that might lead to this error, please let me know.
Thanks.
I've noticed that too. However, if you execute a command in that window , connection will get updated.
There is seems a delay happens when someone changes connection and TaskBar UI element is updated.
