Switch between Editor and Dialog does not work anymore
rene.heusser
I have installed Version 6.0.3.893 (MBCS) yesterday. Since then I am not able to switch between the Editor and the Dialog in the command window anymore.
I also could not find any keyboard shortcut which would support this.
When pressing ALT-D the Debug menu drops down, when pressing ALT-E the Edit menu drops down.
I really do not want to start to work with the mouse!
Kind regards, Ren
Dear Scott
Thanks for the hint. I did not know of that option before.
Actually it does work, but having it on ALT-D and ALT-E is just more convenient then CRTL-H.
So if there is a possibility to have it back there would just be great.
Kind regards
Ren
Go to: Tools > Preferences > Key Configuration, then select item "Edit / Next Tab Page" and press ALT-D (or ALT-E). Now you can switch between the Editor and the Dialog tabs with one single handy key combination!
