SQL Window, vertical scrollbar disappears when grid is moved and all text is not visible
Claus Pedersen
Version 8.0.0.1480
I have some SQL code (10 lines). In my window, there is only room for 6 lines, the last 6 are shown. The vertical scrollbar is visible.
Now, I move the border of the SQL grid down, so there becomes room for all lines. The vertical scrollbar disappears, but lines 1-4 are still not visible. Only by navigating to the lines via keyboard (Up arrow), the first four lines become visible.
Either the scrollbar should remain visible to indicate missing text, or all text should move into focus when the scrollbar disappears.
BTW: the same thing happens for the Test Window, if you drag the splitter-bar to the variable list downwards and for the Program window, if you drag the splitter bar for the status window.
