Problem with horizontal scrollbar in SQL-Grid when switching to Single-Record-View and then refresh
ArneHH
unfortunally, the horizontal scrollbar overlaps the last data row of the single record view so that the last row is only partial visible after a refresh (F8)
Steps to reproduce:
  • Select a table with many columns (eg. SELECT * FROM all_all_tables WHERE owner = 'SYS' AND table_name = 'DUAL')
    -> At the bottom of the grid-window therea should now be a horizontal scrollbar. (Which is absolutlely ok)
  • Switch to the Single Record View
    ->The horzontal scrollbar is not shown now (because it is not needed, this is ok)
  • Refresh the single record view (F8 or use the refresh button of the grid view)
    -> The Grid is refeshed, shows shortly the complete list and switches automaticly back to single record view
    -> Now, the horizontal scrollbar stays at the bottom and overlaps the last date row (column), so that you cannot see the content, which is bad
This is reproduceable in:
PL/SQL Developer 15.0.3 (64bit)
In PL/SQL Developer 14.0.5 (64bit) this problem does not exist.
Can this be fixed?
best regards
Arne
