Claus Pedersen
When editing data in sql window, using the large data editor in dark mode, it flickers (first sql grid is shown, then white background, then data in dark mode) when changing record using the up and down arrow icons. Could the change of row data be done more smoothly?
I can not see which record in the grid I am currently editing, is this an error or a feature? There is lot of empty real estate in the bottom of the screen to show it, eg next to or below the data size info.
For example data, use e.g. "select * from all_source" and view column "text" using the ellipsis button
