Sql WIndow: not highlighted executing line
In v14, when I run (Ctrl+Enter) a line in a script, it gets highlighted. In v15 I don't see this behavior. Perhaps a corresponding setting is not taken over when installing the beta version?
The top pane shows v14. Below v15. One Sql Window each with 4 statements. Line 2 (2nd statement) is executed with Ctrl+Enter.
Can you go to Preferences > Program Window and check how the "Hot track highlighting" color is defined?
Ok that's the reason. But then this setting doesn't seem to have been carried over from v14.
A possible reason might be that I use a self-defined color in v14 and this cannot be adopted.
