sql*plus copy
Roadling
is there a comperable command/function in pl/sql developer for the sql*plus copy command?
COPY FROM TO
{ ( ) } USING
thanks
The COPY command is currently not supported by the Command Window. To copy table data you can use the Export Tables and Import Table tools.
You can alternatively type SQLPLUS on the Command Window command-line and enter the copy statement there
