A Au_dote Member Mar 13, 2025 #1 Hello , I have a problem with pl sql 10 on windows 11, when press ctrl and shortcut x or c for copy, then appears charecter, v or c or a.
Marco Kalter Administrator Staff member Mar 13, 2025 #1 Can you try the same with the trial version of the current 16.0 release?
A Au_dote Member Mar 17, 2025 #1 I cant' install new software, installation prohibited. No one had this problem? Last edited: Mar 17, 2025
Marco Kalter Administrator Staff member Mar 24, 2025 #1 I can only suggest that you try this with the latest 16.0.3 version.
William Robertson Member³ Apr 6, 2025 #1 Can you try mapping them explicitly in the Key Configuration preferences page? Find Edit / Clipboard / Cut and set the key as Ctrl-X, and so on.
