Problems with Version Control in PL/SQLDev.
TenGor
Hey,
i found the following problems with the Version Control in PL/SQLDev. We use SVN
- in Chapter 16 Version Control of the help you describe that the Version control statuses are shown in the File Browser.
"After saving a window the status icon will be updated accordingly."
=> This don't work. I had to do a manual refresh in the File Browser.
- the popup of the Version control operations don't use the installed language of TortoiseSVN.
- in Chapter 16.3 Version control operations of the help you describe an icon in the status line of a window.
This icon is not visible. In the File Browser i have access to TortoiseSVN via Right-Click.
- After a revert of a file via the File Browser PL/SQL Dev. don't suggest a reload of the file.
So i need to close and reopen the file...
If i use the popup "Shell" in the File Browser then i get the installed language of TortoiseSVN.
In the popup "TortoiseSVN" in the File Browser i only get the default languate
