Problems with Code Folding
TenGor
Hey,
i have a really big problem with the Code Folding in big Packages (28k lines) (since PL/SQL Dev. 12)
1) After folding a lot of Functions/Procedures in the Packages and jump to the end of the file the Scrollbar is out of sync.
2) If i add new code in the Package every (!) folded Function/Procedure was unfold.
And the bigger Problem: I can't jump to the end of the file anymore. The Scrollbar is at the end, but the code windows shows the
line of code you get if you calc: total of lines - folded lines
This syncs only after reopen the file.
I can provide Screenshots if you want.
I have this problem often as well. It also affects the SQL window. I have to ctrl-A and copy all the SQL out into a new window to be able to see it when it happens.
