Problems with OCI
jorge
I'm having problems when I try execute Query Reporter, because I was installing new Oracle products. Two days ago I as using Query Reporter well, but then (after install news products), I try connect to the database but I don't have response, only I view a window without message, only with th button OK, but I believe that the problem is with OCI because with another client for the database, I cann't connect too, and it's sendding a message about the OCI8.
There is a workarround for this problem.
You should probably use the Oracle Home Selector (a standard Oracle utility) to define the correct Primary Oracle Home. This Home will be used by the Query Reporter.
