Problem with FORALL, ORA-24381
twrzodak
hello,
I have a problem with code that raise ORA-24381, PL/SQL Developer (9.0.4.1644) does not show in SQL WIndows exception raised by Oracle:
CREATE TABLE twr_t1(c1 INT NOT NULL UNIQUE);
DECLARE
  TYPE t_int IS TABLE OF INT;
  lt_int t_int := t_int();
  e_dml_errors EXCEPTION;
  PRAGMA EXCEPTION_INIT(e_dml_errors, -24381);
  lt_int.extend(10);
  FOR i IN 1..10 LOOP
    lt_int(i) := i;
  END LOOP;
  lt_int(5) := 4;
  FORALL i IN 1..lt_int.count SAVE EXCEPTIONS
    INSERT INTO twr_t1(c1) VALUES (lt_int(i));
END;
There is no exception, status in SQL Window is "Done in ... seconds".
There is a problem also in command windows, after executing anonymous block: Warning: PL/SQL procedure successfully completed with compilation errors
In sql*plus is of cource
ERROR:
ORA-24381: error(s) in array DML
ORA-06512: at line 13
Is this a bug?
here is my test case:
CREATE TABLE mytab(col1 NUMBER PRIMARY KEY);
INSERT INTO mytab VALUES (1);
COMMIT;
DECLARE
TYPE t_nums IS TABLE OF NUMBER INDEX BY PLS_INTEGER;
x t_nums;
x(1) := 2;
x(3) := 1;
x(5) := 3;
FORALL i IN INDICES OF x SAVE EXCEPTIONS
INSERT INTO mytab VALUES (x(i));
END;
the execution in command window is also bizarre.
The plsql block is executed successfully and I receive:
"Warning: PL/SQL procedure successfully completed with compilation errors"
