Preferences not copied
Jeff81
My preferences from version 13 did not copy over. I am also using the PREFPATH and RECOVERYDIR override options in the param.ini
If you are using alternative preference directory locations you may need to copy them manually. They are only copied from a previous version when using the default location.
