PL/SQL Developer does not start
After installing PL/SQL on a pentium 4 3Ghz machine the program hangs when starting.
When i install PL/SQL on a pentium 4 2.6Ghz machine the program starts correct. Both machine work with Windows XP Proffesional SP1 and have 512mb memory.
To obtain some more diagnostic information, can you modify the shortcut and add the debug parameter? For example:
"C:\Program Files\PLSQL Developer\plsqldev.exe" debug
PL/SQL Developer 6.0.6.947 02.16873 - 5 user license
27-4-2006 17:19:12 Application started
27-4-2006 17:19:12 InitPreferences
27-4-2006 17:19:12 Load C:\Program Files\PLSQL Developer\Preferences\Default = 0
27-4-2006 17:19:12 PreferenceSet.Load C:\Program Files\PLSQL Developer\Preferences\Default\Default.ini
27-4-2006 17:19:12 PreferenceSet.Load OK
27-4-2006 17:19:12 Load C:\Program Files\PLSQL Developer\Preferences\manz818118 = 0
27-4-2006 17:19:12 PreferenceSet.Load C:\Program Files\PLSQL Developer\Preferences\manz818118\default.ini
27-4-2006 17:19:12 PreferenceSet.Load C:\Program Files\PLSQL Developer\Preferences\manz818118\user.prefs
27-4-2006 17:19:12 InitPreferences end
27-4-2006 17:19:12 SortPreferenceSets
27-4-2006 17:19:12 - Default manz818118
27-4-2006 17:19:12 - System Default
27-4-2006 17:19:12 LoadPreferences
27-4-2006 17:19:12 LoadPreferences searching for default
27-4-2006 17:19:12 C:\Program Files\PLSQL Developer\Preferences\manz818118\default.ini
27-4-2006 17:19:13 LoadPreferences end
27-4-2006 17:19:13 FormCreate Logon.Execute
27-4-2006 17:19:26 LogonHistorySave start
27-4-2006 17:19:26 ChangeUserPref LogonHistory,
27-4-2006 17:19:26 ChangeUserPref DSA,
27-4-2006 17:19:26 ChangeUserPref end
27-4-2006 17:19:26 ChangeUserPref ColumnAssociations,
27-4-2006 17:19:26 ChangeUserPref ImportAssociations,
27-4-2006 17:19:26 ChangeUserPref BrowserFilters,
27-4-2006 17:19:26 ChangeUserPref BrowserFolders,
27-4-2006 17:19:26 ChangeUserPref SessionQueries,
27-4-2006 17:19:26 ChangeUserPref ExternalTools,
27-4-2006 17:19:26 ChangeUserPref Documents,
27-4-2006 17:19:26 ChangeUserPref Reports,
27-4-2006 17:19:26 LogonHistorySave end
27-4-2006 17:19:26 FormCreate Session.Connected
27-4-2006 17:19:26 FormCreate Logon.Executed -1
27-4-2006 17:19:26 FormCreate TDBNames.Make
27-4-2006 17:19:26 FormCreate SessionChanged
27-4-2006 17:19:26 SessionChanged SetDBAViews
27-4-2006 17:19:26 SessionChanged Authorizations.Load
27-4-2006 17:19:26 Oracle Error: Session.
ORA-00942: Tabel of view bestaat niet.
At line 2, position 5
select grantee, name from
sys.plsqldev_authorization
27-4-2006 17:19:26 SessionChanged EnableAuthorizedMenus
27-4-2006 17:19:26 SessionChanged SetSessionAction
27-4-2006 17:19:26 SetSessionAction starts: Main session
27-4-2006 17:19:26 SetSessionAction ends
27-4-2006 17:19:26 SessionChanged ExecuteConnectScript
27-4-2006 17:19:26 ExecuteConnectScript starts
27-4-2006 17:19:26 ExecuteConnectScript ends
27-4-2006 17:19:26 SessionChanged LoadRecentObjects
27-4-2006 17:19:26 SessionChanged Notify children
27-4-2006 17:19:26 SessionChanged Logoff secondary sessions
27-4-2006 17:19:26 SessionChanged SessionMode = smMulti
27-4-2006 17:19:26 SessionChanged EnableChildFunctions
OracleHomeKey: SOFTWARE\ORACLE\HOME0
OracleHomeDir: D:\oracle\ora92
Found: oci.dll
Using: D:\oracle\ora92\bin\oci.dll
It seems thing go bad when loading the OCI library (D:\oracle\ora92\bin\oci.dll). Can you still use SQL*Plus or other Oracle client tools?
After entering the userid pwd and environment on the login panel the program "hangs". When instead of entering the userid, pwd etc on the login panel i press cancel and connect from the main panel the programs does not function properly also. Again this only happens on a certain type of pc (i tested on 2 machines with the same specifications). On other pc's this does not occur and i can work with PL/SQL.
I have downloaded the trial version and installed it. With this version i do not have the reported "problem" that the program hangs when starting. How can i register the trial version with the product key we have for version PL/SQL Developer 6.06 ?
