No "Move" in task-bar right-click menu?
MjH
In most Windows applications, if you right-click on the tab in the Windows task bar, you are presented with a menu that has the following choices: Restore, Move, Size, Minimize, Maximize and Close. On a PL/SQL Developer tab, you only get: Restore, Minimize and Close. Is there a reason why the other options have been removed?
The reason I ask: I have a 2 monitors on my PC at work. When I connect to my work PC from home via Remote Desktop, I can only "see" the primary monitor. If a PL/SQL Developer window that I want to use is on the secondary monitor, I cannot use the "Move" menu selection to get it to the pimary monitor.
Thanks, Maury
