Insert template menu from contextual menu does not work
SebG
After using PL/SQL developer 14 (14.0.2) during several hours in day, the item menu "Insert template" from contextual menu (Right click on sql window) does not work anymore.
I need to close PL/SQL developer and to restart it.
"Templates" for Windows list are working fine.
Thanks in advance for your feedback on this issue.
Seb.
Difficult to reproduce as this happen after using PL/SQL developer during several hours. We noted no special actions done that could be the root cause.
I have the same problem. In my case it allways happens when disconect from remote desktop, and connect again, Plsql Developer is minimized and after maximized his visual interface don't show correctly, buttons are overmounted, and I need to press: Restore and Maximize button to correct this. After that, the item menu "Insert template" from contextual menu (Right click on sql window) does not work anymore.
