We have several developers who are having issues seeing the full list of views from the dba_* dictionary with code assistant. They have been granted the 'SELECT ANY DICTIONARY' privilege and it is reflected in querying dba_sys_privs.
Only 21 objects show up in the code assistant list after they type dba_ , but they are able to successfully query from all of the dba_* views. I have had one of them delete the CodeAssistantHeight registery key suggested in a different post and then restart, but that made no difference.
They do have "Use DBA Views if Available" selected, and everything in Code Assistant is checked. We are all using Version 11.0.6.1776 64-bit with this group using an Oracle 11.2.0.4.x database.
