Code Assistant not appearing when connected to 23ai
Knut2025
Hi folks,
my shortcut for the code assistant to appear is CTRL+SPACE. When I am connected to ATP 19c (Cloud DB 19c Transaction Processing) the code assistant appears when hitting CTRL+SPACE. It does not when I change the connection to an ATP 23ai.
It does not list packages or tables but it lists columns and methods inside a package.
When writing
SQL:
select * from all_tab
and hitting CTRL+SPACE then nothing is listed. But when writing
SQL:
select * from all_tables where owne
it will show the column named "OWNER".
Are the any different approaches to collect the information from the DBs?
Cheers
Knut
For the "all_tab" case he Code Assistant will check all object names to find matching names, and it should have found the public synonym ALL_TABLES for SYS.ALL_TABLES.
To verify, can you perform the following query and let me know the result?
select * from all_synonyms
where synonym_name = 'ALL_TABLES'
Hi Marco,
thank you for your fast reply. Here is the result:
OWNER SYNONYM_NAME TABLE_OWNER TABLE_NAME DB_LINK ORIGIN_CON_ID
1 PUBLIC ALL_TABLES SYS ALL_TABLES 1
And this is not only a table problem but a problem for all kind of objects like functions, procedures, UDT, sequences, ...
The list of public synonyms for the Code Assistant are fetched in a background thread when you connect for the first time in PL/SQL Developer. It may be that this query takes a little longer on your 23ai database, so it may be that you type "all_tab" before the list is complete. Can you wait a few minutes before checking the "all_tab" list?
If this still fails, then to obtain some more diagnostic information, can you modify the PL/SQL Developer shortcut and add the DebugSQL parameter? For example:
"C:\Program Files\PLSQL Developer 16\plsqldev.exe" DebugSQL
Reproduce the problem and send me the debug.txt file that is generated in the %APPDATA%\PLSQL Developer 16 directory (e.g. C:\Users\\AppData\Roaming\PLSQL Developer 16).
