Wrapping PL/SQL Code
Kari
we have closer to 100 PL/SQL packages. Is there a way how to wrap these in one go?
tia,
Kari
ps. The Oracle version is 10gR2
You can do this in 3 steps:
1. Use the Export User Objects tool to export the packages to source files (1 file per object).
2. Generate a script that performs the wrapping. For example:
set feedback off
set heading off
spool w:\exports\wrapall.cmd
select 'wrap iname=' || o.object_name || '.bdy'
from user_objects o
where o.object_type = 'PACKAGE BODY'
order by o.object_name;
spool off
set feedback on
set heading on
You can run this script from the Command Window.
3. Run the generated wrapall.cmd script from the Windows command line.
already this helps a lot.
Still, having this kind of "bulk" wrapping feature included in PL/SQL Developer would nice.
Kari
