As a test, can you disable the splash screen by adding the NoSplash parameter to the PL/SQL Developer command-line. For example:
"C:\Program Files\PLSQL Developer\plsqldev.exe" NoSplash
You can also add the following line to the params.ini file in the PL/SQL Developer directory:
NoSplash=1
