and...
You have simple query (in sql window):
select t.*, t.rowid from a t
in current schema only table "a" exists.
and now place the cursor in different places and right click:
1) when you place cursor "|" after the first "t":
select t|.*, t.rowid from a t
onpopup is called like in BE trace:
2005-03-24 09:37:01 : Opening Popup menu for item: Type=SQLWindow, Owner=PLTOOLKIT, Name=, SubObject=
2005-03-24 09:37:01 : Opening Popup menu for item: Type=TABLE, Owner=PLTOOLKIT, Name=A, SubObject=
2)
select t.*, t|.rowid from a t
2005-03-24 09:37:54 : Opening Popup menu for item: Type=SQLWindow, Owner=PLTOOLKIT, Name=, SubObject=
Popup is not opened for any table object!
3) and 4)
select t.*, t.rowid from a| t
select t.*, t.rowid from a t|
When cursor is after a or last t the onpopup call is similar to first case
... but when in current schema table "t" exists the right click behaviour is little different:
1)
2005-03-24 09:44:36 : Opening Popup menu for item: Type=SQLWindow, Owner=PLTOOLKIT, Name=, SubObject=
2005-03-24 09:44:36 : Opening Popup menu for item: Type=TABLE, Owner=PLTOOLKIT, Name=A, SubObject=
2)
2005-03-24 09:44:56 : Opening Popup menu for item: Type=SQLWindow, Owner=PLTOOLKIT, Name=, SubObject=
2005-03-24 09:44:56 : Opening Popup menu for item: Type=SQLWindow, Owner=PLTOOLKIT, Name=, SubObject=ROWID
2005-03-24 09:44:56 : Opening Popup menu for item: Type=COLUMN, Owner=PLTOOLKIT, Name=T, SubObject=ROWID
3) and 4)
2005-03-24 10:02:42 : Opening Popup menu for item: Type=SQLWindow, Owner=PLTOOLKIT, Name=, SubObject=
2005-03-24 10:02:43 : Opening Popup menu for item: Type=TABLE, Owner=PLTOOLKIT, Name=A, SubObject=
It looks to work ok when you select "t" or "a" character.
And another one case:
Try to select or place a cursor within a "from" keyword (when "t" table exists).
The popup is called for:
2005-03-24 09:54:49 : Opening Popup menu for item: Type=SQLWindow, Owner=PLTOOLKIT, Name=, SubObject=
2005-03-24 09:54:49 : Opening Popup menu for item: Type=SQLWindow, Owner=PLTOOLKIT, Name=, SubObject=ROWID
2005-03-24 09:54:49 : Opening Popup menu for item: Type=COLUMN, Owner=PLTOOLKIT, Name=T, SubObject=ROWID
Greetings,
Joachim Rupik
