We have ORA-12569 in PL/SQL Dev
Alexander
Hello!
I've created database link from 10.2.0.2 to 9.2.0.7:
create database link ETL
  connect to DATA_LOADER
  identified by ************
  using 'etl.inf.sonicduo.com';
for our programmer.
But if he try to expand 'Database links' in PL/SQL Dev on his work machine he receive the error message ORA-12569: TNS:packet checksum failure
I can expand 'Database links' on my machine and i can use ETL database link:
SQL> select 555 from dual@etl;
       555
       555
And we are using the same version of PL/SQL Dev 6.0.3.893
Could anybody help me in this case?
To obtain some more diagnostic information, can you modify the shortcut and add the debug parameter? For example:
"C:\Program Files\PLSQL Developer\plsqldev.exe" debug
Was anything learned? We are experiencing the same error message when we try to expand the database links for one of our schemas. We are on PL/SQL Developer version 7.0.3.1123 going against an Oracle 10.2.0.2.0 database.
Not really. Can you do a similar test? Modify the shortcut and add the debugsql parameter? For example:
Sorry, didn't log back in in a while to see that you responded so quickly. I do appreciate it.
We have since isolated that this error is occurring when we create a database link from an Oracle 10.2.0.2.0 database to another an Oracle 10.2.0.2.0 database. It does not occur when we go from a 10.2.0.2.0 to a 9.2.0.7.0 database. In generating the debug file, I did notice that my current Oracle home was a 10g home. On a whim, I changed my Oracle home in preferences from auto-detect to my 10gR2 Oracle Warehouse Builder home. After I restarted PL/SQL Developer, I was able to expand the Database links node in the objects tree in the GUI. That appears to be a viable workaround.
I will be sending you a fail and a succeed debug file for your information.
