ORA-12154 error with PL/SQL Developer - not with SQL Developer
LoriS
I realize this subject has come up several times in the past, and I've tried some of the suggested solutions, but they have not worked in this case.
I am using a laptop provided by a client to login to their network instead of using VPN and logging in from my personal laptop (security reasons).
I am able to connect to the database using SQL Developer, but receive the ORA-12154 error when using PL/SQL Developer.
Support Info is below.
Thanks for your help!
PL/SQL Developer
Version 10.0.5.1710
01.97376 - 5 user license
Physical memory : 4,072,464 kB (1,728,064 available)
Virtual memory : 2,097,024 kB (1,768,656 available)
Parameters
Preferences
Session mode: Multi
OCI Library: C:\Oracle\instantclient_12_1\oci.dll
Use OCI7: False
Preference Files
C:\Users\stebbla\AppData\Roaming\PLSQL Developer\Preferences\default\Default.ini
C:\Users\stebbla\AppData\Roaming\PLSQL Developer\Preferences\STEBBLA\default.ini
Plug-Ins
*Active Query Builder (C:\Program Files\PLSQL Developer\PlugIns\ActiveQueryBuilder.dll)
*PL/SQL Documentation (plsqldoc) (C:\Program Files\PLSQL Developer\PlugIns\plsqldoc.dll)
*Red Gate Deployment Plug-In (C:\Program Files\PLSQL Developer\PlugIns\RedGate.dll)
*Version Control Interface 1.2 (C:\Program Files\PLSQL Developer\PlugIns\VCS.dll)
(* is Active)
Homes
OraClient11g_32 (C:\Oracle\Ora11g_32\Client11g)
OraClient12Home1_32bit (C:\Progra~2\Oracle\Oracle12c_32\product\12.1.0\client_1)
DLLs
C:\Progra~2\Oracle\Oracle12c_32\product\12.1.0\client_1\bin\oci.dll
TNS File
C:\Oracle\TNSNAMES\tnsnames.ora
Using
Home: OraClient12Home1_32bit
DLL: C:\Oracle\instantclient_12_1\oci.dll
OCI: version 11.1
You will need to review the definition of the database you are trying to connect to in the tnsnames.ora file (C:\Oracle\TNSNAMES\tnsnames.ora).
Is the connection definition in SQL Developer using TNS? I think up until recently it only used JDBC and therefore would not have looked at the tnsnames.ora.
Hi guys,
Thank you for your response!
I am able to connect from SQL Developer version 4.0.0.13 using the same TNSNAMES.ora file specified for PL SQL Developer.
Do you have any other ideas?
I really appreciate your help!
~Lori
Can you check if you can connect to the same database with C:\Progra~2\Oracle\Oracle12c_32\product\12.1.0\client_1\bin\sqlplus.exe?
On the Windows Command Prompt, do the following:
c:
cd \Progra~2\Oracle\Oracle12c_32\product\12.1.0\client_1\bin
sqlplus /@
Hi Marco,
I tried this, using the following convention:
sqlplus myusername/mypassword@Host/servicename
I received the following:
ORA-12592: TNS:bad packet
Enter user-name:
So then I entered myusername and mypassword as per the prompts, and received the following:
ORA-12560: TNS:protocol adapter error
SP2-0157: unable to CONNECT to ORACLE after 3 attempts, exiting SQL*Plus
Any further ideas?
Thanks so much for your help with this!
~Lori
It seems that the Oracle Client has a problem. I see that you have 2 clients installed. Can you start PL/SQL Developer without connecting, go to Tools > Preferences > Oracle / Connection, select "OraClient11g_32" from the Oracle Home selection list, restart PL/SQL Developer, and try again?
Hi Marco,
I've tried this, and still get the same error: ORA-12154: TNS:could not resolve the connection identifier specified.
I also tried:
1) downloading the 32-bit Instant Client 12.1
2) changed the oracle home setting in the params.ini file to:
# oraclehome=C:\Oracle\instantclient_12_1
3) changed the OCI Library to: C:\Oracle\instantclient_12_1\oci.dll
This has worked for me on other workstations, but not on this one.
I also tried turning off the Windows firewall and connecting, but this also did not work.
I am hoping you are aware of some other parameter or setting that is needed? I am also checking with our DBAs and sysadmins to see if there is something that needs to be enabled on their end.
Any further assistance you can provide is greatly appreciated! :)
~Lori
Marco,
I worked with an internal data administrator and copied his sqlnet.ora, ldap.ora, and tnsnames.ora files that he uses for Toad.
This did the trick! I am now able to connect to the databases using PL/SQL Developer.
Happy Holidays!
~Lori
