Visible Margin color
Ivan C.
Is there a way to change the color of the Visible Margin in the Editor windows (SQL Window, Program Window, Test Window, etc.)?
I'm running PL/SQL Developer Version 9.0.5.1648 01.73920 on Windows 7 Professional, 64-bit, and Visible Margin's color is something very close to white (light grey maybe?) which makes it very hard to see on a white background. By now, I'm used to highlighting several lines of code (which, by default, uses a dark blue background) to be able to see the Visible Margin.
I remember in earlier versions of PL/SQL Developer, Visible Margin had a different color, which, on white background, made it much easier to distinguish.
