Claus Pedersen
On scott/tiger, I have the following code snippet from inside a package:
If I perform code completion after the dot in the last statement in method tester2 ("myRecord."), I get the column names from table emp ???
I would have expected x and y.
If I rename the loop variable myRecord in method tester1, code completion in method 2 now works.
PROCEDURE tester1 IS
FOR myRecord IN (SELECT * FROM emp) LOOP
NULL;
END LOOP;
END;
PROCEDURE tester2 IS
TYPE myType IS RECORD (x NUMBER, y NUMBER);
myRecord myType;
myRecord.x := 1;
myRecord. -- perform code completion here ...
END;
