Using debug session to manually get variable values
After I start a debug session, I want to execute sql in debug session in order to obtain value by hand.
Is that possible?
I was using this, which ends up in error (xec is always 28).
SQL:
declare
  xec  binary_integer;
  buff  varchar2(2000);
  xec := dbms_debug.get_value('varname', 0, buff);
Is there something wrong in this picture?
Tnx
This is indeed not possible. The dbms_debug.get_value function can only be called from the controlling session, to which you do not have access. You can only obtain variable values through the normal PL/SQL Developer debugger functions. You can also execute SQL code within the debug session when execution is paused through the "Execute SQL in debug session" button on the debugger toolbar.
So "executing in debug session" executes a query in target, rather than debug session?
