Unable to view Tables from PL/SQL Developer
Shanks
After upgrading to PL/SQL 8.0.1.1502, I am unable to see the tables under my table view. I have checked my access permission to the data base also and they are fine. I checked the option 'Use DBA views if available' and log off and on but still I am not able to view tables or views.
I am able to run queries from the SQL screen.
Can anyone suggest why this is happening after upgrading to this version ?
Shanks
If your previous version was 7.1 or earlier, then maybe you are overlooking the user selector at the top of the Object Browser? By default it is set to , so that you will only see tables owned by the currently connected user. Set it to the corresponding owner or to to see other tables.
