-sorry but your bug in command window is not good. i writing at first line note and hints.
(if last character is '/' then your parser dont work correctly.) can you repair it.
Somehow the comment inside the multi-line text causes a problem, with as result that the trailing semi-colon is not removed. Replace it with a trailing '/' on the next line to circumvent this.
We'll fix it.
