topic: At least two issues in PL/SQL beautifier in PL/SQL Developer v7.0.3
There are at least two issues in PL/SQL beautifier. See below.
Before and after PL/SQL beautifier was invoked... (PL/SQL Developer v7.0.3.1123)
+ BEFORE +
CREATE OR REPLACE PROCEDURE abc(v_command_type IN VARCHAR2,
                                v_table_name   IN VARCHAR2) IS
   -- set global table name
   set_table_name(v_table_name);
   $IF trace_level > 3 $THEN
   /*  -- comment lines inside / * and /  will increase indentation everytime when PL/SQL beautifier is invoked
   -- test comment line
   trace('command type:' || v_command_type);
   $END
END;
+ AFTER +
   $END
   END;
2)
+ BEFORE +
   -- $IF followed by IF with no line in between will merge into one line and screw up the format
   -- of following statements when PL/SQL beautifier is invoked
   $IF dw_installed = 1 $THEN
   IF v_command_type IN ('INSERT', 'UPDATE')
   THEN
      --  comments ...
      v_tag := v_command_type;
   END IF;
   $END
END;
+ AFTER +
   $IF dw_installed = 1 $THEN IF v_command_type IN ('INSERT', 'UPDATE') THEN
   --  comments ...
END IF;
$END
END;
3)
+ BEFORE +
   $IF dw_installed = 0 $THEN
   -- comments...
   v_tag := 'DELETE';
   -- $END followed by EXCEPTION/BEGIN/IF with no line in between will merge into one line and screw up the format
   $END
EXCEPTION
   -- comments...
   WHEN OTHERS THEN
         trace('ERROR');
         RAISE;
      END;
END;
+ AFTER +
   -- comments...
   v_tag := 'DELETE';
   $END
   EXCEPTION
   -- comments...
   WHEN OTHERS THEN BEGIN
   trace('ERROR');
   RAISE;
END;
END;
