Tooltips in code on secandary monitor - 13.0.6
fabrice
When i open a procedure, function or package, if you put your cursor on a cursor name, you obtain the cursor declaration in a tooltip.
This work fine on my primary monitor but not on my secondary monitor.
I tried to uninstall/install again, but no change.
Is someone else have this problem or is there something wrong on my computer?
the same tiny empty rectangle appears when code assistant is activated. This feature was functioning fine before and does not depend on the monitor I use. It makes code assistant impossible to use.
Can you exit PL/SQL Developer, start regedit.exe and go to the following section:
HKEY_CURRENT_USER\Software\Allround Automations\PL/SQL Developer 13\Preferences
Delete the keys starting with "CodeAssistant", restart PL/SQL Developer, and check if this helps.
