I recently added a 3rd monitor and when I started PSD, all my toolbar settings were lost. The same thing happened a different time when I changed resolution. After some investigation, I found a toolbar configuration file in the PSD %APPDATA% folder which appears to have the monitors and resolution built into the filename - "Monitors_1600_1280_1280.toolbar.ini". After I renamed the previous config file to match new resolution, my toolbar settings were loaded correctly.
Is there a reason the configuration file has to contain the monitors and resolution in the file name? Will I lose my settings every time I change a monitor settings- I really don't change them but this issue has happened twice already. Is renaming the old configuration file the only way to restore the settings?
Joe
Joe
