Problems Setting Fonts in PSD
Orestes
I just got a bigger monitor so I tried to adjust the fonts in PSD.
Big mistake! Some dialogs got ugly, others were downright unreadable because the line size of the dialog did not adjust properly for the font and some lines got clipped.
What's more some changes only showed up after logging out of PSD and back in again allowing me to dig myself into a deeper hole before I knew what was happening.
Eventually I got it working. The fonts on some menus and dialog are a bit small, but acceptable.
Three questions:
1) Is there a way to quickly rollback to the out-of-box font settings for PSD?
2) How do I back up my current settings so that they can quickly be restored should I mess things up again?
3) Is the adjustment of fonts in PSD documented anywhere?
Support Info follows.
Regards,
Jim.
PL/SQL Developer
Version 10.0.5.1710
13.88829 - 50 user license
Windows 8 (64-bit) 6.2 Build 9200
Physical memory : 4,194,304 kB (4,194,304 available)
Virtual memory : 2,097,024 kB (1,762,912 available)
Parameters
C:\PLSQLDeveloper\plsqldev.exe
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
C:\PLSQLDeveloper\Preferences\Default\default.ini
C:\Users\jims\AppData\Roaming\PLSQL Developer\Preferences\JimS\default.ini
Plug-Ins
*Active Query Builder (C:\PLSQLDeveloper\PlugIns\ActiveQueryBuilder.dll)
*CPAS Development Tools (C:\PLSQLDeveloper\PlugIns\CPASPlugIn.dll)
*PL/SQL Documentation (plsqldoc) (C:\PLSQLDeveloper\PlugIns\plsqldoc.dll)
(* is Active)
Aliases
DST
LDEV
LDEV201
LISTENER_LDEV
MARLAP
Homes
OraClient12Home1_32bit (C:\oracle\product\12.1.0\client_1)
DLLs
C:\oracle\product\12.1.0\client_1\bin\oci.dll
TNS File
C:\oracle\product\12.1.0\client_1\Network\Admin\tnsnames.ora
Using
Home: OraClient12Home1_32bit
DLL: C:\oracle\product\12.1.0\client_1\bin\oci.dll
OCI: version 11.1
Oracle Database 12c Enterprise Edition Release 12.1.0.1.0
Character Sets
Character size: 4 byte(s)
CharSetID: 873
NCharSetID: 2000
Unicode Support: True
NLS_LANG: AMERICAN_AMERICA.WE8MSWIN1252
NLS_CHARACTERSET: AL32UTF8
Your preferences are stored in the following directory:
%APPDATA%\PLSQL Developer\Preferences\
In your case:
You can backup and restore this directory, or you can delete it to start with default preferences.
