timestamp portion not showing when examining variable of date datatype in debug mode
It is expected behavior, but it can be enhanced. The date (and time) value is displayed in the nls_date_format. If you want to test procedure xyz and display date variables with time fraction, you can simply modify your test script like this:
  -- Modify the nls_date_format for the session of the test script
  dbms_session.set_nls('nls_date_format','''DD-MM-YYYY HH24:MI:SS''');
  -- Run the procedure
   xyz(p1 => :p1, p2 => :p2);
