Test Window SQL reported differently in V$SQL
Ivan C.
SELECT statements (I haven't checked other SQL statements) get reported as all upper-case in V$SQL.
When I execute the same statements from SQL Window, Command Window, or from SQL*Plus the statements get reported in V$SQL "as is". No case changes.
Also, when executed from Test Window, comments from SELECT statements are removed (not hints) in V$SQL.
My DB's cursor_sharing parameter is set to EXACT.
Is it possible that Test Window is setting this parameter to FORCE for the session, internally (I didn't find a Preference for it)?
I can't find another explanation for such behavior.
I cannot reproduce this. The v$sql view shows the SQL exactly as entered in the Test Window, including case and optimizer hints.
Here are the steps to reproduce it:
1. New Test Window
2.
declare
  l_number number;
  select /* comment_for_v$sql_identification */ count(*)
    into l_number
    from dual
   where 'A' = 'B';
3. Execute Test Window
4. New SQL Window
5.
select * from v$sql
 where lower(sql_text) like '%comment_for_v$sql_identification%';
Query in step 5 only returns itself and the PL/SQL block from step 2. The query from PL/SQL block was not in result set.
6.
select * from v$sql
 where lower(sql_text) like '%where ''a'' = ''b''%';
Query in step 6 returns the PL/SQL block from step 2 and the following:
SELECT COUNT(*) FROM DUAL WHERE 'A' = 'B'
I'm doing this in PL/SQL Developer 9.0.6.1665, running on a Windows 7 Pro, 64-bit, while connected to an Oracle Database 11g Enterprise Edition Release 11.2.0.3.0, or to an Oracle Database 10g Enterprise Edition Release 10.2.0.5.0
We witnessed the same behavior on a different machine (also Windows 7 Pro, 64-bit), running PL/SQL Developer 9.0.5.1648, while connected to an Oracle Database 11g Enterprise Edition Release 11.2.0.1.0
Please let me know what other info I can supply you with, if any.
This issue is somewhat concerning (at least for us), since code run from Test Window is generating a SQL with different signature (hash, sql_id, etc.)
than the one we're trying to debug/test.
This is apparently standard Oracle Server behavior. I get the exact same results when executing the PL/SQL Block from SQL*Plus.
You're absolutely right, Marco.
This is happening for any code executed from an anonymous PL/SQL block, even if the code being executed is a pre-compiled PL/SQL object (such as function or procedure).
Thank you for looking into this.
