Test Window Problem
sukhadukkham
hi all,
i have problems with the test-window when placing the cursor over a two-dimensional array while debugging. doing this causes pldev to completely hang and the only solution is to use the task-manager to kill pldev and restart. please find a simple test for this below
CREATE OR REPLACE TYPE AR_NUM AS VARRAY(2147483647) OF NUMBER
CREATE OR REPLACE TYPE AR_AR_NUM AS VARRAY(2147483647) OF AR_NUM
CREATE OR REPLACE PROCEDURE DEBUG_TEST
AS
  lar ar_num := ar_num();
  lar_ar ar_ar_num := ar_ar_num();
  ln_dummy PLS_INTEGER;
  lar.EXTEND(10);
  FOR
    i IN 1..10
  LOOP
    lar(i) := i;
  END LOOP;
  lar_ar.EXTEND(10);
  FOR
    i IN 1..10
  LOOP
    lar_ar(i) := lar;
  END LOOP;
  FOR
    i IN lar_ar.FIRST..lar_ar.LAST
  LOOP
    FOR
      e IN lar_ar(i).FIRST..lar_ar(i).LAST
    LOOP
      --------------------------> PLACE CURSOR OVER ARRAY HERE
      ln_dummy := lar_ar(i)(e);
    END LOOP;
  END LOOP;
END DEBUG_TEST;
hi marko,
any news about this? it's very important for me to have this working as we are working intensive with varrays.
thanks for the good work
daniel
hi marco,
just to let you know: the same problem happens, when placing the curser over :new or :old values while debugging.
regards
daniel
hi marco,
i tested this with toad 9.0.1 and their debugger does not have any problems with this. so this seems not to be an oracle server bug.
daniel
tested this with 7.1 beta 2:
placing the cursor over the lar_ar(i)(e) expression leads not to a complete hang of pldev anymore. but you still may not see the actual value.
