Test Script SQL Example
Sam68
According to the documentation for 9.0.6 for Testing Programs
5.7 Viewing result sets
In a Test Script you are not limited to PL/SQL blocks. You can also execute single SQL statements, including select statements. Executing a select statement will display an additional Results tab page, which displays all selected rows.
The following Test Script generates Oracle Error:
ORA-06550 PLS-00103: Encountered the symbol "SELECT"
-- Created on 1/17/2013 by SMALICKI
declare
-- Local variables here
i integer;
-- Test statements here
:A := 'test';
Select t.IMEI_ID
into :A
From CONT_IMEI_HISTORY t
Where t.IMEI_ID = '000000999';
Select t.IMEI_ID
Does anyone have an example of how to format a select statement for the Test Script envirionment so that the output will be genereated on a new Results tab?
Thx, Steve
From my experience, you can only execute EITHER a Pl/Sql block OR a single Select (without trailing semi-colon).
Also, you can execute multiple queries from within Pl/Sql block like this:
open :first_resultset for select ..... ;
open :second_resultset for select ..... ;
But in this case you will have to:
1) Assign Cursor type to each bind variable
2) Execute block
3) Open each result set in separate window
I see a couple of things. The Bind variable is not set up. Also, after blocks, you need a forward slash to execute it. We don't have the same table, so I can't make sure it will work, but a similar example worked for me. Try this (but remove the mike comments):
VARIABLE AA VARCHAR2(100) -- mike added.
DECLARE
i INTEGER;
:AA := 'test'; -- Mike Changed.
SELECT t.IMEI_ID
INTO :AA
FROM CONT_IMEI_HISTORY t
WHERE t.IMEI_ID = '000000999';
END;
/ -- Mike added
SELECT t.IMEI_ID
Mike, that will work in a Command window - OP is asking about Test windows.
A Test window can only contain one statement - either a PL/SQL block or a SQL statement. (Therefore it does not support delimiters between statements, so no trailing ';' for a SQL statement.)
