Test script, returned result is marked with yellow background, result can not be seen in dark mode
Claus Pedersen
When testing e.g. a function, the returned value is saved in a variable called 'result'. When the result is different from the previous result, the value is marked with a yellow background (when run the first time, the previous result is null, so therefore it is always marked).
But the result can not be seen in dark mode, only the yellow background. When navigating away from the field and into the field again, the value is marked (black text on a blue-greenish background), so it can be seen. But it is hard to e.g. copy a part of a result string, because the background keeps shifting back to yellow.
