Test Script for PipeLine functions
Buzz_ss
Hi.
When I create Test Script for pipeline function using popup menu
I get code like as :
declare
  -- Non-scalar parameters require additional processing
  result MyPackage.TMyPipeType;
  -- Call the function
  result := MyPackage.MyPipeFunc;
I would prefer to get code like as
SQL:
select * from table(MyPackage.MyPipeFunc)
Is it possible?
Hi, just insert the select in a for ... loop like this
for r in (select * from table(MyPackage.MyPipeFunc)) loop
dbms_output.put_line(r.?);
end loop;
Hi.
I talk about autogenerated code! I want the Test menu to make code like as
SQL:
Is it possible?
Jens Naumann said:
I don't think so. Because test contains always a plsql-block.
Regards
Why do You think so? Try write
SQL:
select * from dual
in Test window and press execute button. You will get correct result in page 'SQL Output'.
I don't know what kind of test window you mean. I do it like this
- file/new/test window
- for me it's created with an template plsql-block
- delete all, write "select * from dual", execute => ORA-00933 or
- wite "select * from dual" into the plsql-block, execute => ORA-06550, PLS-00428
It is very strange
All works correctly. I see new page "Sql output" and result in it.
I very often use such operations .
How do You test queries which have parameters?
As example
SQL:
select * from dual
where 1 =:a
this is impossible in SQL window. You can use for it Test Window only!
Ok. Try
1) to write in SQL window "select * from dual"
2) Execute.
3) If preview step worked correctly, do right click.
4) PopUp menu :"Change window to Test window"
5) Execute
I don't see that it is possible. I use templates to add to the test script that is generated or I manually change them, because I don't know of a way to modify how they are generated.
Another thought is to save a test script, open it and modify it as needed if most of it stays the same.
Even if a Test Window has to be a PL/SQL block, the generator could still create something like
    open :results for
        select * from table(MyPackage.MyPipeFunc);
with :results provided as a cursor variable.
    open :results for
PL/SQL block is not necessary for test window.
HTML:
works fine in Test window too.
Buzz ss,
Thanks for the tip about adding
SQL:
In all my years of using PL/SQL Developer, I had never noticed that the Test Window contained a SQL Output tab! (I can be kinda slow that way!)
So I always wrote convoluted ways to display the results of a pipeline function in a Test Window.
Thank you very much!
- Stew
Jens,
Is there a chance that your "SELECT * FROM dual" had a ; at the end?
When I add that, I get the ORA-00933 error you reported below.
I find that it works fine (w/o the semi-colon) in PL/SQL Developer 12.0.7.
Happy trails,
Stew
Hi Stew,
without a plsql-block You can execute a sql-statement without an ending ;, that's true. But for me this test maskes no sense because it's just like a sql-window. I use test windows only for debugging of database packages or triggers and they contains always a plsql-block.
Regards
