Tabbed result in SQL Window shows wrong CLOB
jhughes
I discovered a glitch when running multiple SQL statements from the SQL window. I did a quick search on the forums and didn't see this posted, but please let me know if I missed it.
Our 10g db table structure is a simple parent/child table relationship where both the parent and child have a CLOB in them. I have the following two SQL statements coded.
SELECT *
FROM child
WHERE primary_key_col = 528;
SELECT *
FROM parent
WHERE primary_key_col = 1331;
I select both and hit F8 to run. The results come back on the separate tabs. When I click the ... on the first tab to view the CLOB, it is actually showing me the CLOB from the parent table. If I run the SELECT for the child table alone, it correctly shows me the CLOB in the child table.
If I switch the order of the SELECT statements around, so that the child table is last and run both, both tabs show the CLOB from the child table instead.
Jason
PSD info
PL/SQL Developer
Version 7.0.1.1066 (MBCS)
178.30864 - 20 user license
Physical memory : 523,760 kB (101,312 available)
Paging file : 885,632 kB (440,272 available)
Virtual memory : 2,097,024 kB (1,977,144 available)
Parameters
Preferences
Session mode: Multi
OCI Library: C:\oracle\ora92\bin\oci.dll
Use OCI7: False
Plug-Ins
Homes
OraHome92 (C:\oracle\ora92)
OraHome92_1 (C:\oracle\ora92_1)
DLLs
TNS File
c:\oracle\tnsnames.ora
Using
Home: OraHome92
DLL: C:\oracle\ora92\bin\oci.dll
OCI: version 9.2
Oracle Database 10g Enterprise Edition Release 10.1.0.4.0
Character size: 1 byte(s)
