Syntax Highlighting on Insert Statement
MannyO13
When I click a variable (n_company_id) syntax highlighting works as expected...
But when I click on the same variable inside the insert statement, it does not highlight all instances of n_company_id...
Why? How can I fix that?
The insert column highlighting takes precedence over the variable highlighting. There is currently no option to change this behavior.
This seems like a major flaw.
It should do both, column and variable highlighting.
The discussion about it was already here about 3 years ago.
Unfortunately, it ended without results. :-(
Maybe it could be realized as suggested by MannyO13. Because the current solution is very inconvenient to use.
