Stephan B
Hi all,
I just ran into an issue I hope you can help me with. I haven't found any answer using search here or via google.
I try to build a template to comfortably insert substitution variables, using substitution variables.
As part of that template I want to have something like this line:
so that it results in the following line when for example 'My hint' is entered:
If nothing is entered, the line should be empty.
Using the above code results in the error "Substitution variable not properly terminated".
Is there any chance to escape the double quotes properly?
&<name="Hint" hint="A short parameter description" type="none" prefix="hint=\"" suffix="\"">
hint="My hint"
