Error when using substitution variable in SQL Window
MartinF
I am getting an error when using substitution variable in SQL Window.
When running the following command in SQL Window
SQL:
GRANT SELECT ON acpnuxeo_ogi.hierarchy to &tst.nuxeo_ogi;
I am getting the following error:
ORA-00933: SQL command not properly ended
When running exactly the same command in PLSQL Command window it work fine
SQL:
SQL> GRANT SELECT ON acpnuxeo_ogi.hierarchy to &tst.nuxeo_ogi;
Grant succeeded
Any help appreciated
Regards,
Martin
The SQL Window use an enhanced substitution variable syntax. It does not implicitly remove the "." after the variable name. You would need to use this syntax instead:
GRANT SELECT ON acpnuxeo_ogi.hierarchy to &nuxeo_ogi;
See also chapter 12.3 "Variables" in the User's Guide.
