Strange behaviour at compile package
mike_
I am collide with a strange problem -
At compiling package body, PSD just hangs on. Opposite, compiling the same file via SQL*Plus is ok. Compiler parameters are identical in sql*plus and psd.
In trace file for such session only "sql net message from client" and "sql more data from client" events have a large values.
Do anyone have any assumptions about reasons of such behavior?
Thanks!
