sql window: dot (".") should end substition variable
Bernhard S
the dot currently does not end a substition variable in the sql window.
I issue the following sql:
select 'prod&reg._dba.my_table' test from dual;
In SQL Window I get asked and enter:
Name Value
reg 01
Result is: prod01._dba.my_table
(note the dot after 01 here!)
In Command Window I get asked:
Enter value for reg:
and I enter again: 01
Result is: prod01_dba.my_table
(no dot after 01 here!)
In SQL*Plus behaviour is the same as in Command Window.
I think, behaviour in SQL Window should be adapted and dot should end substition variable, but also not be shown in result value.
Regards,
Berny
The substitution variables in the SQL Window are different (and more powerful) than in SQL*Plus or in the Command Window. See chapter 10.3 in the User's Guide for more details.
The equivalent in the SQL Window is:
select 'prod&_dba.my_table' test from dual;
Thank you for your answer. That solves my problem. :)
Didn't think about checking the "Reports" section regarding this issue, even though that's already mentioned in chapter 6.3 too.
Berny
